96Q45GAL wrote: Well my question is when I unplug the connector while the car is in park... Is it suppose to idle a little then SHUT OFF?
In other words, yes, or ... sure. Don' worry about that. You need a working MAF. Good luck on the next try. It's such a simple infuriating problem - you'll be amazed how much more you'll like the car when it's over.Q45tech wrote:As a safety measure lack of air flow [either real or a drop in 1.2 volts from MAF at idle] shuts off fuel pump after the expiration of high mode TIME [depends on coolant temp at start up ~ 5-30 seconds] to fill rails and create pressure on start up.
Turning on key create a 0.5 volt MAF signal, a running engine create a low of 1.1 volts running hot idle 750 rpm to 1.4 volts cold 1500rpm idle.
60 mph [2000 rpm steady] will be around 1.6 volts
Maximum MAF voltage is around 4.4 volts at 6000+ rpm loaded on the road at WOT!
MAFs going out really aren't notorious. No reason to throw money away on a new one. My $75 junkyard MAF is perfect.maxnix wrote:Or at least get a known good new MAF from Joe.
How can you have a 1.2V drop when it's supposed to sit at 1.1V at hot idle?Q45tech wrote:a drop in 1.2 volts from MAF at idle
No doubt this is due to the low resale value of the Q, which in time becomes a $500-2500 car purchased by poor people with little education who think they are getting quite a ride for the pennys spent....until their new shiny toy cries for $$$ in maintenance or repairs, and not having the funds, the car sinks into disrepair, further plummeting its value and safety until it becomes a lawn ornament or parts junker- see them all around the city,driven by young thugs that look like they are minimum wage mcdonalds workers...quite rare to see a G50 driven by anyone in a suit downtown anymoreQ45tech wrote:Not saving the $250 per month [$3,000 per year] always leaves you short in Q repairs.
Old Q are known the ramling wrecks of the Lux car industry, even the old Lexus are better maintained by the ministers/ state reps stealing from plate or hocking the church building.
No, it is worn.tmorgan4 wrote: My $75 junkyard MAF is perfect.
Do you make commission?
