here's my parts list for my rb25det swap
MOB240
Car: 1995 nissan 240sx
this is just the basic parts list for me to get the s14 on the road. feel free to chime in if im missing something, or if there's something on my list that you know where i could find it cheaper. any info/advice would be greatly appreciated! thanks!
PART PRICE SOURCEWater pump 89.00 Enjuku Oil pump 350.00 enjukuTiming belt and tensioner idler pullies Clutch 305.00 JGYALL accessory belts flywheel Fuel filter Fuel pump Spark plugs Metal head gasket(get head and block resurfaced) ARP headstuds 139.00 JGYQ45 throttle body Koyo alum. Radiator Flex-a-lite dual 320’s intercooler BOV Boost controller Tophat mounts 350.00 Custom driveshaft ??????? ?????Spliced harness 329.00 Wiring specialties
LayinLo
Car: Accord, Gixxa
I would use the Syko Performance Swap Kit.
It's $585.00 but I think they are doing a group buy right now.
http://www.sykoperformance.com/prod01.htm
LayinLo
Car: Accord, Gixxa
Here's the link for the driveshaft. Either aluminum or steel.
http://www.driveshaftshop.com/240parts.ivnu
rotorimp
Car: 02 Xterra, 60 IH Metro
Why are you going to get the head and block re surfaced? Is the motor blown? Unless you are trying for over 450-500 right out of the box there is no reason to pull the head off. save the money and buy a greddy manifold. Use the same oil pump unless you have crank collar problems in which case you will be rebuilding the motor. The water pump is the only thing I definitely recomend replacing straight away. Don't buy a KOYO they ALL leak get a Griffin--they don't leak (same price). Recirculate your BOV or it will stall when you come off throttle. You will also need someone to fabricate a cold and hot pipe.
P.s. Don't forget the most important thing when doing a RB swapLots of $$$$$$$$$$
s14kouki
Car: 1998 240SX SE
Quote »Engine set w/ x-member SYKO conversion kit w/exhaust elbowConversion driveshaftExhaust downpipe-SR20DET Electric fans of your choice (FAL recommended) Upper and lower radiator hoses (R33)BeltsS14 radiator or aftermarketFMIC w/ tubing, couplers, & clamps (or use stock side mount) Misc. (oil, coolant, spark plugs, o2 sensor)
LaborConversion laborWiring service
Optional PartsAir filter kitFuel filter Z32Walbro fuel pumpPower steering cooler kitUpgraded clutch Greddy intake plenum (new BOV will be needed if you get this)battery relocationnismo thermostatnew water pumpfront and rear main sealsrear transmission sealLSD (so you dont constantly spin 1 tire)
If you have an automatic then add:
clutch master cylinderclutch pedalbrake pedal (or cut stock)clutch hardlineclutch line from hardline to slave (or buy a one piece SS braided made to go from master to slave)shifter trimshift knob[/quote]That's the list i came up with, i just copied and pasted it from the group buy thread. You can change it accordingly to work with whatever mounts you eventually use.
MOB240
rotorpimp, i saw that you also live in surprise...you think you can take me for a spin in your 240? haha dang i wanted to be the first to swap the rb25 in surprise...you beat me to it! what kind of mods do you have done to your 240?
rotorimp
My car just got painted so the Rb is out of the car getting pretty(powdercoating,greddy manifold) so you may have yours on the road before me! The turbo is still stock, fuel injectors and FMS is still stock other wise EVERYthing else is custom. How far are you into your swap?
MOB240
lol i dont even have the rb25 yet...i should have enough money by this summer. its nice to know there is someone local that has a 240 w/rb25det...do you think you could help me out w/my swap when i get it? do you do all the work on your car at your house or do you have a shop?
rotorimp
I do welding/fab work on the side---Can't wait to see another 240 W/ An Rb
let me know when you get started--I stay busy--But i try and make time for the RB guys!
MOB240
what kind of mounts are you using for your swap? i want to go w the tophat ones but ive been reading alot of bad things about them...how much hp are you going to end up with when its all said and done? when you get done with the swap you should take your 240 down to speedworld lol i dont think ive seen a 240 there yet with an rb!
rotorimp
I made my own mounts--I'll tune it to 400 at the wheels--I do occasionally go out to speed-world when they have something going on. Are you going to school here?
MOB240
im in my last semester of high school lol but yea ive been out to speedworld quite a few times...but when they have big events, you be lucky to get in 3-4 runs...the lines get so long! i went out there last summer for midnight run and i only got to run 2 times! i definately want to see your car when you get that rb25 in man! do you have an s13 or s14?
rotorimp
I have a S13--I just repainted it factory green and for now I have infinity G35 5 lug wheels (black)--Keep an eye out for me in the next couple of months.
MOB240
are the mounts you made yourself stronger than tophat mounts? ive been reading lately on here that the tophat mounts suck...you think you can fab me up a set? lol oh and what the hell were they doing @ luke afb today? i heard one of those jets break the sound barrier! haha
Modified by MOB240 at 1:26 PM 3/23/2007
DRIFTING.com
Parts List/Source
R33 Skyline Front Clip - (Sr20Store.Com)Syko Performance Rb25 Converted Upper And Lower Harness - (Sykoperformance.Com)Syko Performance Motor Conversion Mounts - (Sykoperformance.Com)Syko Performance Transmission Brackets - (Sykoperformance.Com)Syko Performance Sway Bar Brackets - (Sykoperformance.Com)Syko Performance 1 Piece Driveshaft - (Sykoperformance.Com)Intercooler Piping - (Sykoperformance.Com)Intercooler Core - (Meganracing.Com)Couplers And Clamps - (Hosetechniques.Com)Power Steering Cooler - (Sr20store.Com)S13 91+ DOHC Power Steering Lines And Fittings - (Milano Motorsports)Greddy RB25 Intake Manifold (Purchased From (Phase2Motortrend.Com)Rb25 Intake Manifold Gasket - (Phase2Motortrend.Com)Infiniti Q45 Throttle Body - (Junk Yard)Infiniti Q45 Throttle Body Gasket - (Purchased From Infiniti Dealer)Apex-I Power Intake - (Apexi.Com)Apex-I Power FC & Commander - (Apexi.Com)Apex-I Auto Timer - (Apexi.Com)Flex-A-Lite Low Profile Dual Radiator Fans (#220) - (Flex-A-Lite.Com)Clutch Stage 3 Upgrade - (Specclutch.Com)Flywheel - Stock Resurfaced RB25 Flywheel - (Taken To Local Shop)Steel Braided Slave Cylinder Line - (Sr20store.Com)Braille Auto Compact Lightweight Battery - (Brailleautodevelopment.Com)STOCK S14 Radiator (Milano Motorsports)High Pressure Fuel Injection Hose (Local Autoparts Store)Z32 Fuel Filter - (Purchase From Any General Auto Parts Store)Walbro Fuel Pump - (Phase2Motortrend.Com)S14 Throttle Cable - (Rhddesign.Com)Fuse Box Bracket - (Custom)5 Quarts Of Torco Full Synthetic 5W-40 Racing Oil - (Torcoracingoils.Com)3 Quarts Of Torco Gear Oil - (Torcoracingoils.Com)Radiator Fluid - (Local Autoparts Store)Power Steering Fluid - (Local Autoparts Store)
rotorimp
Yes the mounts are MUCH stronger!! They are not add on-I cut the factory mounts and built them to the RB once I had it properly oriented in the engine bay.
They are having an airshow today and tomorrow.
