ttrank »
https://forums.nicoclub.com/ttrank-u90506.html
Fri May 29, 2009 2:40 am
Hello all,
Here's some shots of my 04' G35 Sedan with what I consider a ton of mods for your consideration.
Here's the mod list:
Engine & Drivetrain649whp and 651wtq- Wiesco 8.8:1 pistons- Tomei Rods- Cosworth bearings- GT Motorsports Heads- Jim Wolf S1 Cams & Valve Springs- Greddy Twin Turbo Kit with 2000 degree coated manifolds & turbo exhaust housings- Greddy Front Mount Intercooler- HKS SSQV Blow Off Valves x3- Custom air intakes behind front grille with AEM Dryflow filters- NGK Plugs- Kinetix SSV Intake Manifold- Nichols AutoFab Oil Catch Can- Greddy Oil Cap- Custom Grounding Kit- Sun Hyper Ignition & Hyper Voltage systems - AMS 50mm Radiator- FAL Fans- Earl’s 6x13 Oil Cooler with Spal Fan- WR Power Steering Fluid Tank- Greddy Profec B SPec II Boost Controller- Turbo XS UTEC with tune by UMS Tuning- Turbo XS Tuner- JDM Right Side Battery Cover- Carbon Fiber Battery Covers- Rogue Engineering Short Shifter- Carbonetic twin plate clutch and flywheel- Upgraded power steering cooler- Carbon Fiber 350Z Engine Cover
Exhaust:- Vibrant 3" downpipes with 2000 degree coating- Wastegate dump tubes 2000 degree coated & routed back into down pipes- Custom Nichols AutoFab dual rear muffler, dual 3" exhaust (Only dual muffler G35 sedan of its kind)
Suspension:- KW V2 Coilovers - Stillen Sway Bars- SPL End Links- Rare JDM Rear Strut Bar - Richie’s Front Strut Bar Covered in Carbon Fiber- GT Spec Rear Lower Tie Brace- GT Spec Rear Lateral Arm Brace
Brakes:- Front: Rotora 380mm x 34mm 12 Piston- Rear: Rotora 355mm x 32mm 4 Piston- Rotora C2 pads - ATE SuperBlue Fluid
Exterior:- Kurookie front bumper- Nismo Side Skirts- Nismo Rear Valance- Custom Made Headlights including:S2000 Upper Headlight Projectors & Acura TL Bi-Xenon Lower Projectors with BMW ZKW lens 6000K Phillips Ultinon HID BulbsAAC CCFL Angel EyesExterior matched paint
- iForged Aero 20x8.5F 20x10R- Nitto NT-05 255/35/20 & 275/35/20- 20% tint- 2006 Taillights tinted & clear coated GT-R style- JDM Bump Style Clear corners with 30 LED PCB boards in each- 3M Clear Bra on bumper cover, hood, A-pillars, side skirts, headlights, door edges, rear bumper, and lower half of doors
Audio/Video:- Eclipse AVN 6600 Navigation Head Unit with Sirius & iPod.- Eclipse back up camera- JL Audio 1000/1 & 450/4 amps- Stinger 15 farad capacitor- 2 JL 12W6v2 Subs in fiberglass enclosures- Focal K2 Mids & highs- Optima Red Top
Interior:- Black Suede Sparco Milano 2 Seats- Forged Performance Shift Knob - AutoMeter Nexus gauges in custom center dash & A-pillar pods (Boost, EGT, Wideband A/F, Oil Temp, Oil Pressure and Fuel Pressure) The controller is behind the glove box.- All LED Interior bulbs- KP Technologies VDC By-pass Module- Mirror Tilt Module- Window Module- Valentine 1 with Mike’s Mount
Alarm:- Python 2-way remote start with window modules, interior temp sensor & trunk pop.
