Here's and idea for a motor build. Am I forgetting anything?
Discuss topics related to the VG and VE series engines.
TJcars2
Car: '87 Acura Legend
VG33E w/ .5L overbore & 9.5:1 Compression ratio
VG30DETT forged connecting rods
Port & polished head with 266 cams & heavy duty valve springs
555cc injectors w/ nismo fuel pressure reg./in-line pump
Reflashed ECU
Z32 MAF
Ported intake plenum w/ throttle body spacer/collant bypass/EGR bypass
Volant cold air intake
Twin electric cooling fans
160* thermostat
2.5" header back stainless exhaust w/ flowmaster super 44 dual in/dual out
Wideband o2
And the car it's going in.....well it's just gonna something different.
Let me know if I'm forgetting anything at all. Thanks.
wrxratd
Car: 1990 240sx hatch, 2002 WRX
If you find yourself in a situation where you have e85 regularly available i would maybe up the c/r to closer to 11:1, but other than that, sounds pretty friggin sweet!
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
If you're going to keep it normally aspirated the 555 injectors will likely be overkill, 370's should be more than enough for an NA application.
Also, I don't recommend the Flowmaster 40 series for the VG... they don't sound the greatest from past experience... very, very, very loud inside the car.
TJcars2
Ok cool. Thanks a lot.
I really don't want to have to deal with headaches every time I start the thing.
What muffler would you recommend?
Return to “VG30 / VE30 Forum”
