Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Wed Dec 29, 2004 4:50 pm
First off, if your 90 is a XE or base model and you want all the things you want, then I'd sell it and look for a 91-93 but in working condition. With the money made from the sale of the 90, I'm sure you'll be able to add some money and find a 91-93. If you get a 91-93 with ABS then it comes with everything you need, which includes VLSD, HICAS, and Power windows/locks.
If built properly, the KA-T will be a sweet engine. But in my case, it's a little spendy compared to buying a SR... but I went the SR route so knowing exactly how much a KA-T costs, I have no clue.
Trying to find parts for your 90 such as abs and vlsd will be rather difficult. If you can do without them however, I'd stick with the 90 and build it up to save money. But that's me, if you are going to build something, make sure you'll be satisfied with the end result because if you say went with the cheapest route, you may not like how the car ends up.
For me, my route was a bit expensive and I worked my butt off to get enough money to mod my car, even so, I didn't regret a single thing, I think the money I spent on my car is well worth it.
No matter what route you go, I say think about it over and over again because once you start, you can't really stop and start over without already wasting a lot of money. SOHC turbo is not a bad way to go either if you are going to rebuild the engine but if you are going KA-T I'd recommend new pistons and rods, preferably aftermarket reinforced... which aren't cheap.
