Here's a little problem I've not seen posted before
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Hi Guys,
On both 94s my steering wheel developed a clicking sounding as you slightly turn it from from dead center. Its subtle but annoying. It seems to fade during cold weather.
Removing the front cover shows nothing, comming in from the back and applying a little pressure around the black 4" gasket with a small screwdriver stops it.
I would remove the wheel and give it deeper look but I'm afriad of the airbag.
Anyone else have this?
Peter
Q45tech
Like most no preventative mainteance [lube] to any part will eventually allow some wear and noise to develop.
The air bag requires some serious Joules to explode. Discoing it [after you disconnect battery to avoid sfter restoration lights] is safe unless your vehicle gets struck by lightning during the process.
Peterofdevon
It makes sense that its a lube issue. Thin lube on a warm day will be very compliant.
Is there a thread on steering wheel remove?
I need a wheel removal tool as I remember.
Peter
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
if you are doing this on a 94 't', remeber that there is a sensor in there for the hicas control. fsm has the notes.
