Here is what I got from consult cable so far
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
From ECU Talk and Microsoft Excel
From ECU Talk:
From Conzult
And a picture of my Q from which the above data was extracted.
Got knock sensor code and also O2 sensor code.
Modified by mxr662 at 10:23 PM 4/19/2007
Q451990
Nice screen shots! How did you create those?
Heath
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Couldn't one just do a print screen and save to a bitmap image?
mxr662
Did a print screen(ALT-Print Scrn) and pasted into wordpad document one at a time. At home I pasted the images into Microsoft Paint and saved them as .bmp. I had my 15 year old son with his learners permit driving so I could do the screenshots. On the highway had him punch the gas so I could try to see the timing advance. His reply was "I want a fast car like this but not so ugly".
Andy
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
mxr662 wrote:"I want a fast car like this but not so ugly".
Naivete begets truth.
Those wheels do make a statement.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Did you just build that excel sheet yourself or did you have a template or something? That's much better than trying to decipher the comma separated info.
qsiguy
Actually I figured it out mostly already. How did you turn the headers at a diagnal?
mxr662
qsiguy wrote:Actually I figured it out mostly already. How did you turn the headers at a diagnal?
select the top row then rightclick on the selected area.
select format then the alignment tab.
it's on this tab.
qsiguy
Can you do me a favor? Boot up ECU Talk again while in your car. Turn on ALL of the gauges. Take a friend with you and get the car up to temp, 178 is where I was at. Go out on some open road and take it up to 60 mph/2K rpm in D (overdrive) and keep it there. I set cruise on mine. Do a screenshot and post it.
I'm trying to diagnose my car but I'm not sure where the gauges are when everything is ok. Make sure you don't have any codes. Check then with ECUTalk before the test.
I would really appreciate it! I installed a resistor in place of one of my knock sensors tonight and the code never came back on. With any luck that will help my emission test. I think I'll go in tomm. morning and get a retest now that my knock code is staying cleared.
FYI Here is the screenshot I am trying to compare. This is with the knock sensor bypass in place.
mxr662
qsiguy wrote:Can you do me a favor? Boot up ECU Talk again while in your car.....
My car is out of service due to under plenum work. Will do when complete.
zerothread/245231
