Here are the Pictures
PoorManQ45
You guys asked and I will now deliver. Here are the pictures that I have so far. I will post more when I can get some money to buy more film and have them developed.
PoorManQ45
Front
PoorManQ45
Throttle Body Off of Plenum
PoorManQ45
Throttle Body
PoorManQ45
EGR with hoses replaced. I couldn't get it to come off. So, I left it on and sprayed carbureator cleaner into it periodically. I think I'm going to clamp it off anyways. Stupid thing. Look what it did to my plenum. The EGR is what caused all that build-up. . So, I'll be getting out my handy dandy Vice Grips and clamping that ***** shut
Modified by PoorManQ45 at 12:48 PM 9/20/2004
PoorManQ45
Plenums Off
Notice the front page of the users manual in the upper right corner. That thing was completely useless
PoorManQ45
Close up of hoses near the TB on the plenum
PoorManQ45
Looking in the valley from front driver's side
PoorManQ45
From front looking into the Valley
Notice the corrosion on the main heater pipe. Also, notice the corrosion on the Metal Y.
PoorManQ45
From the passenger side
PoorManQ45
Near EGR
PoorManQ45
Here's the problem
QShip
Keep up the good work!
PoorManQ45
Those are all the pictures that I have so far.
I have replaced all the hoses except for the two that come off of the Metal Y and the one that is near the IAC.
I figured, while I was in there, I might as well replace the fuel lines with some better stuff. . So, I did that. All 100psi hoses.
I am thinking about replaceing the rubber hoses that come from the Brake Fluid resevoir on the passenger side. They look a little worn.
I still have to replace the PCV valve. I can't find anybody that has the right size hoses to fit the Metal Y . Stupid Nissan , they had to make there stuff an odd size. I think I am going to have to go to either the Nissan or Infiniti Dealer for those two . Those two are probably going to cost more than I paid for all of the other hoses .
Anyways. I'll try to get some more film today. I should have more pictures by the end of the week. I'll be selling them as "Art Work".
Looks good!
rsiwicki
Car: 95 Q45T
PMQ....just curious as to why you have so many parts with surface rust on them? Is this typical for a car? I don't have any surface rust on any components on my car as I noticed your EGR thingy was very rusty on the outside and mine is still shiny and I don't clean my engine compartment as often as I should. I cleaned it for the first time in 4+ years this past spring.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
RSI
A lot of those EGR things and stuff had some stuff like that... Mine didnt have stuff like that, but there was some here and ther.....
DAEDALUS
Car: 1990 Infiniti Q45
Pics aren't showing for me for some reason. Thar be a ghost in this machine.
pito11213
Car: 2002 Chevrolet Suburban
For anyone having a problem seeing the pictures PMQ put up I uploaded them in my members gallery. Look at these plus some pics of the Q and my friends T-bird that I raced straight up.......Read my post on that next.
http://nissaninfiniticlub.net/...t=500
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Great pictures! Looks like it has seen a lot of salt, and not too many filters.
Cleaning the TB and manifold will be a career. Hope the rogue hoses work for a while after it's reassembled.
Modified by maxnix at 3:19 PM 9/22/2004
Modified by maxnix at 3:20 PM 9/22/2004
PoorManQ45
maxnix wrote:Great pictures! Looks like it has seen a lot of salt, and not too many filters.
The car has never seen salted roads. To my knowledge, at least. There is no rust on the lower body panels. And that is the place where rust from salt usually shows up.
What do you mean, "not too many filters"? I don't understand that statement.
maxnix wrote:Cleaning the TB and manifold will be a carreer.
I used carbureator cleaner first. Then I dipped it in a tub of Purple Power. That cleaned it out very good. Very little scrubbing was needed.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
DAEDALUS wrote:Pics aren't showing for me for some reason. Thar be a ghost in this machine.
there is a bug in the site. you can only view the pictures from nicoclub.com
if you [like me] are signed into nissaninfiniticlub.com , then you get a "remote linking" error.
PalmerWMD
Car: 2004 350Z
Props for all the hard work!And thanks for posting the pics!
Fred...
PoorManQ45
Here are more pictures
PoorManQ45
Here's what the plenum runners by the IAC now look like.
PoorManQ45
I have gotten the metal Y out. Notice the corosion on that metal pipe running towards the firewall. Is that supposed to be like that? Should I replace it?
PoorManQ45
Near EGR
PoorManQ45
This is an example of how I protected the hoses. This method also allows the hoses to make tight radius' without kinking
PoorManQ45
Here are the pieces of crap that are holding me up.
I am even too cheap to go buy the gaskets for them. How do my custom made ones look? I also made the gasket for the Throttle Body.
PoorManQ45
This is the stereo that was in my car. I don't know if I'll put it back in when I'm done. It sounds way better than most car stereos.
