helppppp with sr20det
Volkrps13
Car: Sr20det s13
ok, so whne i first did my relocation, i used crappy 6 gauge titanium wrapped wires.... that worked fine, but look like crap, so i bought 2 gauge wires...
after i installed the 2 gauge wires, the starter wouldnt enguage, so i put the old 6 gauge back on.... after doing that, the starter would crank over, but i wasent getting any juice to 90% of my fuses and relays...
turns out the main fuse was fried.... i fixed that, now every acessory works but my lighter, and im not getting any spark...
im getting plenty of fuel, but idk what else to look for
jdm180
Car: 180
i assume that you did a battery relocation? not sure what your talking about there.
but things to troubleshoot are coilpaks, ignitor chip, sparkplugs, check connections, and check all your fuses again. Alot of times changing the sparkplugs will alliviate the problem at least in my experience so i would say start there.
Volkrps13
Car: Sr20det s13
its got new plugs...
ok, now everything is working, but i just dont have spark
i have 12 volts going to the coilpacks...
my ecu isnt flashing like normal when i reset it.. it flashes twice , then goes blank, then flashes twice
jdm180
Car: 180
hmmm not sure could be a problem with the ecu? but i doubt that right now. i know you said they are new plugs just get some new ones and try it out again. if you said you getting power going to the coilpaks i would say that you fauled out your plugs and they are no longer good. you can try and clean them with a wire brush, sand paper and a lighter but i would say just get some new ones. if thats not it. find a buddy with a sr20 and start switchin out coilpaks
Volkrps13
Car: Sr20det s13
its not the spark plugs, i just bought those today because i thought it might help
