helppp im having problems with my ka24de
240michael
Car: 240sx
well at first my 240 was bogging an i noticed a big loss of power i changed one injector but now the car wont start im pretty sure if i put the old injector in the car will start but it will still run crapy the car was also smoking blue does any one know whats wrong with it ?????????? thanks
Razi
Car: Moo
Perhaps your car is burning coolant.
ZOMG.SR20
Car: 1990 s13
doesnt blue indicate oil
KiMbRoZz
Car: 1997 Q45 Silver on Black
yes blue indicates oil.sounds to me like blown piston rings.
ZOMG.SR20
Car: 1990 s13
i thought of piston rings after the fact hey it give you an excuse to rebuild
240michael
Car: 240sx
i kinda thought that too but i checked the compression on all pistons an they dont have much difference they are all around 150 but the last one does have a little oil on the sparkplug soo i guess it can be the ring thanks!
ZOMG.SR20
Car: 1990 s13
well i did hear of a test to check for oil take out the spark plugs stick a paper towel down inside and turn her over a couple of times if theres oil on it then there you go
i wonder if its possible to have etching in the cylinder wall along with bad rings hhmmm
510forever
Maybe when you replaced your injector, you did not put it right.Oring might got messed up and cause you to flooded and hard to start.And causing the smoke too.
240michael
Car: 240sx
dude thats exactly what happen i found that out like 2 days a go thanks
