HELP! z32 caliper bolts
CusCo_S14
Car: 95 240SX se
im looking for new caliper bolts for z32 26mm calipers that connect the two halves together because 2 of the bolts messed up they are 10mm x100mm 1.25 thread pitch. Anyone know where I could go to get a new set of bolts.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Look up axle and suspension for a 300ZX here http://www.courtesyparts.com/b....html
94_240sx
Car: 94_240SX
Sorry to say this, but those bolts may not be available. z32 FSM clearly says that the calipers can't be taken apart, so some parts are not available at all from the dealership. Good example is small o-rings that go to between the halves. It's not even in the parts catalog. I know some people went to Ace hardware store to replace them. IIRC, I asked Courtesy Nissan about those bolts for 30mm calipers, and they were not available. A couple of mine were rusty, so I tried to replace them when I rebuilt mine. Courtesy Nissan knows very well about z32 and s13/s14 stuff, so give them a call and ask. Worst case, I'd buy a beat up caliper on eBay and take out the bolts and use them. If you can find one 26mm caliper in bad condition, you shoud be able to get it cheap. Good luck and keep us posted.
