Thats what i would suggest, check that the battery is good/connected. I forgot to disconnect mine during a plenum pull and the security light on the inside killed the battery....freaked me out when i got it all back together and it didnt run. Look at it again and let us know whats up.A Paratroopers 300zx wrote:A little more detail would help.
1. Was it running before you tore everything apart?
2. Did you put everything back together in the correct position/order?
3. What all did you mess with?
4. What did you use to clean the injectors and how did you go about it?
5. Did you reconnect the battery? (sounds dumb, but a lot of people forget this lol)
