HELP! WTF is wrong with my Q 45 caliper swap!??!
first time s14 owner
Car: 1997 Pathfinder SE 4x4
Did I get some special Q calipers that are difefrent or what!??!I'm mega-screwed, as I'm doing a 5 lug conversion at the same time, so my car is off the ground and wheel and hub-less. My HOA won't like that too much! And it's my only car right now!!
not even close to matching (note the 28 on the caliper, they are 28mm Q calipers)
Kraelic
Car: 89 240sx
What year did these come off of? The ones you want are from 90 to 96 infiniti q45, did you also get the mounting brackets from the Q45 for rotor clearance and caliper bolt location? Be sure to use the bolts from the stock 240 brackets as the q45 ones are longer and will touch your rotors after the swap.
well, it's as simple as misinformation on here...lolI need the Q brackets, even though most posts say you don't!
