VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Oct 20, 2022 3:57 pm
The rear cat isn't monitored, the front cat is. Like I said, you'd get codes from the front one.
The MAF won't calibrate with a "reset", there's a special procedure for it called Idle Air Volume Learn (IAVL). If you didn't do IAVL on the new MAF, that could be your issue all by itself. IAVL matches up the MAF readings with TPS angles in the ECM's memory. Since QR25 ECM's are totally dependent on an accurate MAF, an uncalibrated one is perfectly capable of causing mayhem with no codes at all. I've seen pieces of lint or butterfly wings literally render QR's undriveable.
If you have a 'Droid phone, the apps and adaptor I suggested will cost you a grand total of about $25. Get a VeePeak VP11 adaptor, it's the cheapest one that works right with CVTz50 and they're $18 all over eBay. If it's Apple then there are other packages like Blue Driver, but my understanding is they aren't so good with the CVT. I'm a 'Droid guy, so others can advise you on that count.
