help with z32 brake calipers
kamikazee47
Car: 1990 240sx KA24DE-T(SOLD) , 1995 240sx SE (DD), 1997 240sx SE, 2008 Evo X
How do i tell which of the 2 aluminum caliper i have. i just need to know so i can start ordering parts.
WesTnine9
Car: S13
Check here http://importnut.net/300zxbrakeswap.htmShould have all you need to know about your calipers and an install write up.
SINsanity702
Car: 1991 Nissan 240sx Hatchback LE 5spd (R.I.P.)
1998 Infiniti Q45
if you just need to know what side is what....then simply put them up to the car, the way they should face when installed, and make sure the bleeder screw is at the top for each side.... If you are trying to figure out if they are z32 turbo or non turbo, then i dunno, u have to check a brake spec. book, like from Centric or Bendix..., that might have a caliper dimension u can use to measure. or look for a stamped part number, and try to find a match.
kamikazee47
i was trying to figure out if i have the 26mm or 30 mm caliper. I check that site out already but i am still unsure which one i have.
r3v_v3ng3
Car: 91 fastback ka-t
are you sure? maybe you need to look at the link again and open your eyes . hint: check out the pix
FRnIsmO
Car: 240sx fastback
check the mm between pads, non turbo 26, turbo 30/ nonturbo from 89 or 90 are 26, over that 30mmif iron are 30mm or could be from s14....aluminum are nonturbos...hope helpsdo you know anything about redrilling 4 lug pattern to z32 rotors? i just got full set of 26mms...hate to spend the money on 5 lug kit bla bla
