Yep, I had a spilt hose which threw on the EGR code too. Nice car man. I'm not a fan of lowered Q's, but yours looks pretty good. It's isn't too low. I still don't know why Infiniti designed the Y33 jacked so high in the air?bullittandy wrote:Stumble is coils.
EGR code is likely a bad rubber hose-take a look.
Prepare for the next post to be Maxnix telling you to yank your intake and lick it clean.
Don't recall I have ever heard of it on any Q45. Have you cleaned the EGR valve and the EGR tube in the plenum? Think you might get a code if the former were inoperable and the later were blocked.randyboy wrote:anybody replaced an egr solenoid?
You likely don't have to replace yours. Check all rubber hoses and you'll likely find one that is cracked.randyboy wrote:anybody replaced an egr solenoid?
