help with wot shutter
USsil80
well got my sr in and got it started but as soon as i mash the throotle is shutters real bad for a second then picks up and revs.. then when you let off the throotle to let it go back down to ideal it cuts out.... i have a power fc ecu with commander and it says the timming at ideal is 15 deg..... please help.....
tried searching but could not find a thing
quiksilvia
Car: 95 s14 se
vac leaks?
USsil80
no..... not that i have found....but it is better now that o2 sensor is replaced ..but now it just dies after wot... it will not ideal
Hijacker
Car: '92 240sx Convertible
'94 F-150
just one quick note. it's idle, not ideal.
this sounds suspiciously like an over rich problem. are you running the stock diverter valve, or did you upgrade to a BOV? Also, check your fuel map to make sure you're not running it too rich
