pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sat May 29, 2004 5:41 pm
Well you have to find out if your fuel pump is working, one easy way, is to disconnect the fuel hose that goes onto the engine, and plug it in a plastic bottle or what ever container you got, this way you prevent gas from going all over the engine bay and you prevent any fire hazard situation.when you do that, open your igntion and see if there is gas going into the bottle, try to crank it for about 5 sec and see if you also get some gas, if no gas is coming out, your wiring to the fuel pump isn't right, recheck your wiring. If there is gas going into the container/bottle, then very good chances that your injectors are clogged, keep spraying some more starter fluid and eventually they will kick in, but be prepared to replace them if it is going to take a bottle of quick start to get it going.
PULSAR GTR
