driftin_sr20det »
https://forums.nicoclub.com/driftin-sr20det-u33183.html
Sun Jun 20, 2010 6:48 pm
Well since it has an independent engine harness you should just need to apply electricity and ground to the harness and it will work. Thats how I wired up my 240 dohc swap. And since the ecu runs the fuel pump you will also need to wire that into the relay from the harness also.
