help with wiring, rhd jdm turn signal and wiper switches to usdm harness.
93slicktoptt
Car: 93 300zx slicktop tt, 91 240SX COUPE, 95 hardbody slammed daily
wanted help with a diagram for wiring my s13 us wire harness to jdm switches. it looks like its just backwards on the plugs but i want to be sure. someone has to know so help me out (ive searched and found nothing).also the wiring on the mode actuator is that the same or it that different?
Modified by 93slicktoptt at 6:08 PM 8/10/2009
jdms13vert
Car: s13 vert
im having the same problem now if you find out let me no thanks
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I would guess that it would be the same. What wiring diagram are you looking at? I'll take a look at it and see what I can come up with for you?
93slicktoptt
yea i did figure it out, just match the colors up . the wires are pretty much backwards. i think one wire wont match but once you connect the ones that do they are easy to figure out because everything is backwards . and if you are using the heaterbix from the jdm you will have to repin the mode door actuator plug. if you have the jdm plug just look at how the wires are on there, again the colors match.and i beleive that they were back wards too. if you need any help email me jack300zx17829@yahoocom
