Help with windshield cleaner sprayers
saw102
Car: slawd rogue
Can anyone help with this. The outlets for where the wiper fluid comes out on the windshield seemed to be blocked or are spraying over the car. How can I fix this?Also today on a trip out of town the TPMS light came on and flashed a couple of times . It stayed on, I pulled over to look . I did not turn the car off. When I got back in thelight was off. Tires were ok. Thanks
philipa_240sx
Try to use a small needle or pin to clear any blockage. Try not to rock the needle around as you do this otherwise you will 're-aim' the washer jets. Also make sure there is no ice buildup.
BTW, They should be spraying about 12" up from the base of the windshield.
Return to “Rogue Forum”
