Help with window
qx403
Car: 2003 QX4
I have the 4" auto roll down problem but it is a little worse. The black reset button is missing, it's on the drivers side but broken (i guess) on the passanger side :wtf2: . I see where it would be, there is some plastic with a horizontal slit in it as wide enough to put a quarter's edge in it. I tried pushing it in but that didn't work, any other ideas??
qx403
Car: 2003 QX4
So I was messing around with the slot and stuck my house key in there, then I felt a tingle in my right hand. Awsome, it's just an electrical contact that needs to be made. I used some needle nose pliers and stuck my house key back in the slot to close the contact (without the small shock). After that I followed the procedure in the stickies and now my window is fixed. :mike
