!SHIFT_COUPE wrote:They must have disconnected the battery. Check this thread for a solution.
http://forums.altimas.org/zerothread?id=326810
????? This information is in the vehicle manual.. it shows what to do to reset the window roll up feature... as far as the computer remembering in 10 days..... man, you're 0 for 2!carlositosway wrote:thats happened wen u take out the battery or unplug the window ... give it time may be 10 day i promise the computer will remember that feature.
did you read the posts before youstrangebh73 wrote:to reset the auto roll up feature, roll your window all the way down, then holding the switch in the auto roll up mode, let the window go all the way to the top and continue holding it for five to ten seconds and it should reset, it's a lot easier now you used to have to take the door panel off and hold a reset switch on the motor and perform a certain operation
