Help with wheel size for q45 race build.
subtle_driver
Car: 1989 240sx hatchback, 1990 Q45 5-speed, 1973 Datsun 240z, 1987 Starion Turbo, 2003 Subaru wrx, 1995 Infiniti q45 5-speed,
Hey guys, im currently running some staggard 17" enkei rpf1 wheels on my g50. 8" rear 7.5" front.
I want a wider/square setup if possible.
Does anyone know what is the ideal wheel size and offset for a set of square 17" wheels for my 1995 q45? I prefer 17" wheels and I prefer minimum 8" wide to accomidate the 245mm wide tires. I plan to run 200tw dunlop direzza z2 or hankook r3. I prefer to go wider. 255 275 is ideal, but whatever is affordable and available.
buying a set of proper sized wheels is the first step towards my goal. I am building my car to run autocross, track and drift. But Keep stock interior intact.
If I need to move up to a 18" wheel, I will to accomidate wider tires that are readily available and affordable.
my camber settings are going to be about -4 degrees up front and -1.0 -1.5 degrees in the rear.
thanks!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Not sure about the sizes and offsets for a Q45 specifically, but http://www.rimtuck.com is a great resource to get ideas about what sizes other people are running.
subtle_driver
thanks buddy!
I'll check that out!
