IlyaKol wrote:Stabilizer Links? They are cheap, if you haven't changed them, that's the first place I'd look. I had noises up front too and that's what it was.
front-suspension-overhaul-t586365.html
Hello IlyaKol,
Thank you for your response.
I neglected to add what I've already performed.
Adjustment of all front end components to torque specification.
Replaced sway bar endlinks (stabilizer links?)
New rotors and brakes
New tires
I've narrowed this down to something with the braking system on the passenger side however my mechanic is at a loss and I dont want to start throwing parts at this. My mechanic will definitely allow that.
The important thing to note is that if I'm going down or up a bumpy road, as soon as I apply the brakes the noise stops and when its released it resumes.
TIA
