RicerX »
https://forums.nicoclub.com/ricerx-u125542.html
Tue Oct 28, 2014 6:58 am
4th Gen Altimas (and first gen coupes) are known for their relatively weak OEM brakes. The rotors are prone to warping, and as such pads can wear unevenly.
If you have never done a brake job on your 2008, it's wise to go ahead and do the whole thing - pads, rotors, and fluid (the car is 6 years old now). What you're feeling is very likely a warped rotor, which means you probably should just go ahead and replace the pads along with the rotors (instead of having your rotors turned if in fact you know that the rotors on the car are OEM).
In my personal experience, I ordered hawk brake pads and brembo rotors for my coupe and did the work myself. Those brakes stayed on the car until I traded it. It was more expensive than you'd pay for other brands, but it was well worth it.
Good luck!
