help with vg30 dett plenum
hybred510
Car: 73 510
looking to get stock plenum for vg 30 dett engine . want to know if non turbo plenum will work ???
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Did you find a deal on one?
I'm not sure if the TT and N/A plenum's are interchangable.
hybred510
Car: 73 510
theres one on e bay dont want to buy if it is not going to work non turbo,s are easy to find thats why i wanted to know if they worked thanks for the help jEzTeR
boileralum00
Car: 94 Miata, 95 FZR600R
The plenums themselves are interchangable for the most part. The fittings on the driver's side that connect to the vacuum lines for the brake and clutch boosters, as well as the balance tube, are different between the 2 motors. If you are putting an older plenum on a car w/ newer style injectors (94+TT or 93+ NA were the switchover dates to the newer injector styles, IIRC), you will have to grind a small bit off some of the runners to be able to plug in the injectors on your car.
