Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Jun 14, 2009 3:12 am
The flickering is probably due to a worn out door anchor. Most convertible doors wear the nylon bushing out quickly, and this leaves wiggle room for the door to move when you go over bumps. Order a new one from the dealer, they're cheap. We also have a how to in the FAQ about slipping a bushing on your old anchor as well.
As for popping fuses, have you tapped anything off that line? That line is a constant and makes a good choice to tap into if you need something to be powered when the car is off.
