help with turbo upgrade?
overbaugh240
Car: Cars.. fast cars... i enjoy racing of all sorts
ok last winter i went ahead and did the s13 blacktop sr20det swap into my 96 240sx and this winter i'm gonna put it back up and go for more power ... plans are FMIC i already have intake/ downpipe / full 3'' exhaust and boost controller... besides the front mount i'm have the intake manifold ported and polished i would like to do a turbo upgrade but i have no clue which way to look for that.... can anyone help me out on that... as far as whats good how much and what all is needed..... another thing i want to keep reliability decently high for example if i want to take off and go on a trip somewhere i won't have to worry about sitting on the side of the road... so if someone could help me pick out a setup i would greatly appreciate itthanks,Chris
nissanrcer240
Car: 90 Nissan 240SX SR20DET
First what you need to think about is how much power are you aiming for. For a bigger turbo you would more than likely need to upgrade your fuel system and some sort of tuning, JWT ecu,SAFC, ect. Rocker arm stoppers are something I would definetly look into too if you dont already have them.Depending on your power range theres alot more things you would need.
overbaugh240
I'm would like to reach around 320-350 to the wheels if i could get in that range i would be satisfied...so what all do you think i would need to achieve that ????
DSMs_Suck
Car: Money, *****es, and 40s
If you have money:Get a new manifold and a GT30R (Will support 500- 550 whp and spool decently)
If you want to save a bit:Get a new manifold and a smaller t3/t4 like a T04E 46-Trim or T04E 50-Trim in a .48 A/R T3 Exhuast housing. (Will support up to about 400whp for the 50trim and about 350 whp for the 46-trim, and will spool pretty damn well with the .48 A/R exhuast... probably full boost around 3500 for the 50-Trim, and even a bit less for the 46-Trim)
Personally I would get the standard t3/t4, ball bearing just isn't worth the extra money. For example... Price on a standard t3/t4:http://www.turbocalculator.com...0Trim
Modified by DSMs_Suck at 11:18 AM 9/9/2004
Modified by DSMs_Suck at 11:20 AM 9/9/2004
overbaugh240
alright say if i go with the 46 trim and .48 a/r housing thats on that link you sent.. which aftermarket manifold will i need and what kind of fuel setup and ecu work will i need to do
overbaugh240
robbbby
You will need at LEAST 550cc injectors. The easiest route would be 550's and a SAFC for your fuel correction. If you go above 550's you will need some other sort of fuel management, either a standalone or a rom tune.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
heavythrottle.com i think has a good stock position tubular manifold for the SR...and i would suggest a GT28R or RS (featured in scc for their project car) cuz its' just a good turbo...costly but good
240SXer
Car: 1995 240sx SE (2jz powered)
robbbby wrote:You will need at LEAST 550cc injectors. The easiest route would be 550's and a SAFC for your fuel correction. If you go above 550's you will need some other sort of fuel management, either a standalone or a rom tune.
[sarcasm] Injectors? Who needs them. I'm running GT2540R .86 a/r on stock injectors. I just run 4-7psi and it's slow as hell. That's all you need [/sarcasm]
I got the turbo then ran out of money, now it's only running on stock injectors. It's actually decently fast at 7psi. Probably 220whp or so. These turbos aren't made to run such low boost though.
gt3071r240
Car: 1997 240sx sr20det blacktop
I have a gt3071r turbo and i couldnt be happier with it, on 1 bar of boost the car made 304rwhp. THe car is ruuning on 580cc injector and an apexi SAFC2.
240SXer
gt3071r240 wrote:I have a gt3071r turbo and i couldnt be happier with it, on 1 bar of boost the car made 304rwhp. THe car is ruuning on 580cc injector and an apexi SAFC2.
It depends on your goals. I want to get into the 11s so the best bottom mount turbo seem to be the .86 a/r GT2540r
