Tx-Sx-FS »
https://forums.nicoclub.com/tx-sx-fs-u14620.html
Mon Sep 27, 2004 1:50 pm
i need help with several things... my setup is 1989 Ka24eT -- T3 .48/.60, bov, mbc, SAFC II (will need help tuning), BUT HAVE Ca18det 370cc (when needed), Wablro 255 (if needed at 7psi)1) timing (if just retarding, how many degrees at 7psi?)2) fuel setup (when do i need 255?) 3) injectors (when do stock run out?)4) MAf (when maxed?)5) Where should i mount the turbo on the JGS manifold??
Thats about it for now...if you can help with any or all I would definately appreciate it...TIA
