Help with tires
Nazc0
Car: 2004 G35 Sedan Gray
I just bought a set of stern st-7 rimsfronts are 19x8.5 38 offsetrears are 19x9.5 35 offseti forgot to ask the guy what tire sizes i needi want to got for the widest ones that will fit
johnparkyourcar
Car: 03 DG coupe 5AT
Common tires for that size is 245 and 275. Maybe 255 285?
Nazc0
i just decided to measure them out 245 in the front sounds about right and i got 270 in the back so 65-75 for the back
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
I went from 245's to 275's on my cobra, and wished that I had stayed with 245's on the front due to the way it tracked. (I think 245 and 275 would be a good combo) You might want to stay with the oem tire diameter: http://www.miata.net/garage/tirecalc.html
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You might also consider a 10mm spacer for the front wheels. The rears may rub with 9.5" wheel w/35 offset especially if you don't have enough negative camber dialed in. I'm lower with about -1.8 in the rear and that barely clears the inside of the fender with a 275 and my fenders are rolled as well.
Nazc0
um what about 265?
Nazc0
i decided to go with a 225/35/19 in the frontand 255/35/19 in the backim to scared of the tires rubbing on the fender and i talked with a few people where i bought the tires and they said that it will look greatnow im just waiting for them to arrive and they should be on my car on monday
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
I think you still going to need to have the fenders rolled...
I had min done and it cost me about 100 bux
All you have to do is rent the tool and they ship it too you and then you ship it back!
DJ
Nazc0
if it has to be rolled the people i got the rims from say that they will roll it for mebut they did say that the 255 35 in the back should fit withought problems ill see when i get the tires on mondayi will still have 300 left over for some more toys and im selling my old rims for 400(all 5 of them) so waht should i spend my money on i found an intake for a 350z and it should fit since its the same engine bay but i thought i should ask here its an aem cold air intake
RED_DET
Vendor
2011 Infiniti G37x
Suspension...
Nazc0
elaborate....
