simmode1 »
https://forums.nicoclub.com/simmode1-u73804.html
Tue Mar 24, 2009 9:10 am
I'd rather go with a 40 profile tire than a 45, but either way, it's going to be a tough fit unless you're using tire brands that are known to run small. I.E. Nitto 275's seem to be as wide as Falken 235's. These are just examples, mind you...
You'll need a roll & pull to run these sizes, but it will probably be worth it. This is the same route I'd go.
