Help with timing chain
m1dt0wn3
ok guys, I'm not the smartest guy in the world and when I took my head off I forgot to support my timing chain with the block of wood and it fell down into the block. I can still see it and I was wondering if there was any way I could get the timing chain back up without taking the timing chain cover off? because that would save me a lot of time and headache. thanks guys
m1dt0wn3
c'mon guys bump
ricebike
2002 Quest
2005 Altima
agh, u gotta take it off now! hate to be u. just to be sure that the chain/guides/tensioner are all in place.
might as well check the timing cover for the dreaded signs of chain-rubbing against the cover & making a hole.
m1dt0wn3
dude don't tell me that....i can't stick a coat hanger down there or something?!
180fan
Car: 89 fastback
no you cannot unless you want to take gamble your motor on it when you start it up.
ricebike
2002 Quest
2005 Altima
eggzactly! don't gamble after all that work u put into replacing your head gasket, just to bend/ break a valve or worse...
m1dt0wn3
well **** guys lol...hot much will it cost to have someone professionaly do it?
hotshot240sx
Car: my 240sx
a proffesional timing job on a single books for 9+hours. i myself can do it in 4-5 with a rack! its not really a sucky type of job to do. it just takes patience my friend. and YES you dropped it and lost it. now you have to gut it up! your looking close to a grand roughly off the top of my head. but im shure you can wheel and deal! or i can send you all info needed from my computer to yours on how to do it successfully. its up to you!
m1dt0wn3
allright man....give me the info
hotshot240sx
Car: my 240sx
i will get it to you first thing tommorrow, i am no longer in my shop.
Touchdown038
Car: Computers, cars, sports
There's a writeup on 240sx.org, as well as the actual Nissan TSB on a Geocities server, easily turned up with a Google search.
I will say that it is not as hard of a job as it seems. Pull everything off, replace chain (or put back on in your case), put everything back on. If you can remove the head, you can do the job IMO.
m1dt0wn3
I've allready removed the head...and I'm sending it out, but I dropped the chain and I'm tryin just to get it
Touchdown038
Yes I know, I was saying that if you're mechanically inclined enough to remove the head, the timing chain job is no sweat.
gumby
Car: '89 240sx sohc
yeah that is alot of work. i removed a brand new chain kit from a messed up sohc after i pulled it (obviously didnt save the engine). i remember thinking how much youd have to take apart if it was in the car. might consider replacing it while your in there if its old and the cover is worn. seen kits for $45 +shipping. youll need a puller for the crankshaft pulley and oil pump drive gear though. if you do it make sure you cover the crankshaft bolt threadhole. i could send you the kit $20 +shipping if it help$
assuming you have the fsm but if you dont:http://www.nissaninfiniticlub....10514
m1dt0wn3
actually dude...the guy that owed the car before me replaced it less than a year ago so I'm good to go with that, but thanks man
m1dt0wn3
yeah guys I got it. The timing chain fell down the front cover, and I got it out with a coat hanger...and its still attached to the sprocket!!
DAEDALUS
Car: 1990 Infiniti Q45
On the same tooth? How can you be sure?
Touchdown038 wrote:if you're mechanically inclined enough to remove the head, the timing chain job is no sweat.
What he said. Unless you're absolutely certain about the timing, don't risk it. Get that cover off and do it right.
ricebike
2002 Quest
2005 Altima
mebbe he got lucky! update us when u have it running again!
m1dt0wn3
lol ok...I just sent the head out today, should be ready in a couple days, and then my gasket set comes on friday so I should be set in a week or so
Touchdown038
If you have a week, why not pull it off to make sure the timing is correct? When it fell, who knows if it slid off the sprocket or not?
