help with timing chain guides for 1990 240sx
caleb travelstead
Car: 1990 nissan 240sx coupe
hello my name is Caleb i have a 1990 Nissan 240sx coupe with the ka24 motor.the timing chain guides wore out and is rattling, so i decided to go ahead and replace the guides and sprockets and chain.i really don't know how to do it. if someone can give me some directions on how to do it would be much appreciated.
thanks,
Caleb
Klits562
Car: white s13 coupe
As far as i know you dont even need the guides. I believe i read somewere on here that they are not neededas far as the rest of that check the articles section i believe there is a write up on how to do this.
caleb travelstead
ive never heard of that befor ill look into it. and thank you by the way
Klits562
actually nvm that Im pretty sure you need themI can remember exactly what was said just not were the hell i saw it.I went through the tech articles from nico and it sounds like its a good idea to keep the guides lolYou said you didnt know how to do it?well here you go this should help.http://www.nicoclub.com/articles.php?id=220814
caleb travelstead
hahaha.thank you
Klits562
good luck its a hard job from what I've heard if you can get a friend whos done it before to supervise
caleb travelstead
haha. im gonna need it.i have a friend who works on cars alothes going to help me and he has friends that i think know how to do it
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Klits562 wrote:As far as i know you dont even need the guides. I believe i read somewere on here that they are not neededas far as the rest of that check the articles section i believe there is a write up on how to do this.
The 89 - 90 SOHC motors use use a sigle cam and therefore a single chain guide which is required.
The TSB that referrers to eliminating chain guides is for the DOHC motors that use two chains. The guides for the upper chain can be removed.
