help with these wheels.
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
Hello, I'm needed to know if would fit. The fronts are 17x7 +35 offset with 215/40 tires. The rears are 17x8 +35 Offset 255/45 tires. Right now I'm running stock suspension. I dont really care if they look sunken, just wanted to make sure if they will fit without rubbing the fenders and suspension. Or would I need to get my fenders rolled to get these to fit? Hmm. just got off the phone with the guy and said they may be 17x7.5 and 17x8.5. But anyways would either size fit? I have until tommorrow night to buy them or he's gonna sell to someone else, so I need some opinions asap.
thanks in advance Wei
Juujai
it'll fit your stock suspension fine. if you have doubts test fit it.
it'll be sunken so you don't need your fenders rolled at all.
574-240sx
Car: Nissans, Toyotas, Subaru
the rears might rub a little on occasion, beacause of the 255/45. Stock suspension = monster truck so I think you can get anything to clear.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
anumeric wrote:Hello, I'm needed to know if would fit. The fronts are 17x7 +35 offset with 215/40 tires. The rears are 17x8 +35 Offset 255/45 tires. Right now I'm running stock suspension. I dont really care if they look sunken, just wanted to make sure if they will fit without rubbing the fenders and suspension. Or would I need to get my fenders rolled to get these to fit? Hmm. just got off the phone with the guy and said they may be 17x7.5 and 17x8.5. But anyways would either size fit? I have until tommorrow night to buy them or he's gonna sell to someone else, so I need some opinions asap. thanks in advance Wei
First off why the hell would he put 255's on the rear for??
I would say that you "need" 215/45/17 in the front and you should run 235/40/17s in the rear. The reason I say this is because on a 17x7 215/45 is ideal size since a 40 series it way too low pro and will cause a reduction in ride quality. As for the backs.... yeah 255 is way too wide of a tire for a 8" wide wheel. My wheels are 17x7 wide and I run 215/45/17's. So for every .5 inches of wheel you should step up 10mm tire width respectively. And since the backs will be an inch wider you would step down the tire height by 5mm since 45% of 215 and 45% of 235 is a big difference in tire height. Unless you are going for that stretched look which I think is just F'ing retarded. But that's my opinion. I hope this helps you a little.
SeVa-S13
Car: '05 GTO 6spd
Oh noez, my own nigga posting in the wrong section....I have failed.
And damn, were they really 255's in the back? I thought they were 235's?
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Guys, we have a wheel/tire forum for this exact type post. Moved...
nismofly
Car: 89 Nissan 240SX Hatch
he already had a thread here, i got it
