help with the sr20 wiring harness
phantomfoot
Car: 240sx
i doing s13 black top sr20 into 89 240sx and i have this problem with the lower SR20 harness (not the KA) has only 1 plug on it that connects to the middle plug of the row of 3 plugs on the passenger fuse box. is this correct?
are they any way to make this work because i don't have the KA lower harness.
plz help me PP. i spend 2 months of my paycheck for this swap and trying to make it run.
Thank
Modified by phantomfoot at 3:03 PM 7/29/2009
vdub62387
I need help with that also, been trying to figure it out. Do you have a 180sx gauge cluster?
phantomfoot
Car: 240sx
vdub62387 wrote:I need help with that also, been trying to figure it out. Do you have a 180sx gauge cluster?
they told me to use KA lower harness for that.
i don't have 180sx gauge cluster.
do i need 180sx gauge cluster ?
or just use the Ka cluster?
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Use the KA harness. The only thing is, you'll have to use the SR starter plug. It's black/white. Remove the KA starter plug and solder the SR starter wire w/ plug to the KA harness. The SR lower harness works as well. But if it's missing plugs, then find one (KA) at a local junkyard.
You don't need a 180sx cluster. Use the one in your 240, but with a 91-94 KA transmission VSS.
