Help with TCC solenoid
Kyleag89
Hello I am new to the forums and just acquired a 2001.5 Pathfinder from a coworker. It needed an IACV valve and torque converter lockup solenoid. I already ordered a Hitachi IACV from rockauto, but the $40 TCC solenoid was out of stock. The only other option they have available is a $170 solenoid. Does anyone know where I can find a cheaper part or I am stuck paying $170? I really cant afford that right now and I'm trying to get this truck back on the road to get to work. Thanks
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Kyleag89
I think that is it, I'll have to do some part # cross referenece to make sure. Thank you so much!
QX4Donuts200
Car: 2003 Infiniti QX4
Hello,I ordered a ROSTRA TCC solenoid from Rock Auto 6 Wks ago. Perfect & Fairly fit /replacement for my 2003 Infinity QX$ RE4R01A ,It is also known as the lockup solenoid on ebay.
Also purchased the 3 pack of solenoids on ebay-yet to have a use for them>don't think they are the issue>would have to drop valve unit to replace.
I am curious as to what issue's or solution you were having..?
My trans it bucks and kicks between 3rd & 4th Gear! Wont stay in gear> RPM stick until pedal feathered with foot. Very smoooooth in lower gears around town( No issue).
It has the TCC Code & 02 Sensor code> Changed Solenoid>Still jerky & kicky.The fluid & Pan were good when dropped> since changed all fluid
Thanks & Best of Luck
heavy hitter
Car: 2001 QX4
