help with taking injectors off the rail.
smokey240sx
I tired everything from vices, removing FPR, to destoring the injectors completely. It seems like there some type of suction. the SR injectors are the same and I don't want to destroy those. am I doing something wrong? and yes I remove the metal clips holding the injectors.
Structure240sx
get a flat head screw driver under the injector clip on the injectors and rock it side to side while pulling on the injector
Jookmasta
i would suggest vice grips, and rags and elbow grease. if you plan on using the vicegrips, grip the top of the injector while holding the rail down with ur foot. do this only with ur stock injectors as u probably wont be needing them.............
PapaSmurf2k3
Site Admin
take the fuel rail right out, flip it upside down, put braces on either side of the injector, and pound them out with a hammer. you might need some sort of punch. only do this if you dont plan on re-using the injectors.
smokey240sx
I about to ditch this whole set up and get some 525cc top fed injectors.
skatanic28
Car: 96 240sx
unplug the injectors.remove the caps.thread the cap screws back in about halfway.use small flatheads to pry the injectors out by the indents in the top using the screws as a fulcrum.
Craving4Boost
Car: 91 240sx fastback
i suggest something nice and pointy...i had this thing with a lil curve at the tip and it was pointy so it poked right into the injector and poped it out..forgot whats it called though...do not use anything to grip it because you will just tear up the injector
MarkEmark
Car: fully-built '95 240sx KA-T
They are a PITA no matter what you do.
BUT, be VERRRRY careful NOT to bend the fuel rail. They bend sooo damn easily; I've personally bent two inadvertantly. You can bend them back fairly easily but they'll never be as straight, and this could cause problems sealing the injectors into the intake manifold, possibly causing, say, boost leaks.
crzycav86
Car: 93 Nissan 240SX KAT
I donno if this'll help, but it's worth a shot:
Open up the gas tank cover to relieve some of the pressure.
virus77
Car: 95 S14, 71 240z, 97 e320
Take two very fine tip flathead screwdrivers and wedge them in between the injector and the rail, then just pry it up a bit, stick the other screwdriver in and it should pop right out, just be sure to get the original screwdriver in deep so it has alot of injector to grab, or else you will break the platic on the injector. I get them out in about 20 seconds each at most. Dont worry if you break the injectors plastic a little, only the two injector o-ring seals really mater for them to work right.
GhostDrifter
Car: 91 240SX
I've tried all the ways and the way skatanic28 posted is the easiest
Structure240sx
mine always come out no problems ever
crzycav86
..because you lube them up properly when you reinstall them.
Structure240sx
lube just helps them go in without tearing. the fuel would clean off any lube it can touch right away
Craving4Boost
crzycav86 wrote:..because you lube them up properly when you reinstall them.
i never had to lube my injections before going in..usually i set them in...get a flathead screw driver...turn it upside down and lean it on the injector...then i take a hammer and LIGHTLY tap it in..works like a charm
crzycav86
All I know is that my stock injectors were a pain in the *** to get out.
When I installed the new injectors, I put a layer of automotive grease on the o-ring, and when I removed them later that day, they slid out like warm butter.
smokey240sx
Project injectors swap was a complete failure. I'm not about to destroy the 370cc injectors so I guess its time for some 525cc with top fed rail.
1WheelWonder
Car: 1991 Nissan 240sx
Looks just like mine the first time I removed them finger and all.
Craving4Boost
hahah nice cut! ive had that plenty of times..at least you got proof your a real hands on guy =)...thats how my stock injectors sort of looked like...not that extreme though lol..you'll get used to it and it wont be as hard..no need for top fuel rail
smokey240sx
Craving4Boost wrote:you'll get used to it and it wont be as hard..no need for top fuel rail
i don't want to get used to this. it funny that i never feel the pain whenever i work on my car. But once i get a splinter i cry like a lil girl.
Structure240sx
OMG what the...
theres no need for that. twist/spin them around a lil, get a screwdriver under that clip ( its notched perfectly) and twist the screwdriver while pulling on the injector with your hand.
Jookmasta
man u must have sum unbent anger or some serious stress cuz u f'd that injector pretty badly. patience is the key. they will loosen up and u'll be able to spin/turn em by hand but they wont come out. u just have to either hit the bottom of the injector with a rubber hammer or vice grip em. wear some gloves next time cuz as said b/f, u have the battle scars of the stock injectors.................
Craving4Boost
Jookmasta wrote:man u must have sum unbent anger or some serious stress cuz u f'd that injector pretty badly. patience is the key. they will loosen up and u'll be able to spin/turn em by hand but they wont come out. u just have to either hit the bottom of the injector with a rubber hammer or vice grip em. wear some gloves next time cuz as said b/f, u have the battle scars of the stock injectors.................
haha yeah that injector does look pretty beat up....probably beat it with a hammer after taking it out to release anger
WDRacing
Thats what happens when you use pliars to remove stuff. I never had any problems like that at all and mine were in for 165,000 miles.
smokey240sx
I was using the screwdrive method. And it slipped. i was determine to get the injector out one way or another.
grimple1
Car: 95 240sx Zenki
Probably would've been easier to just swap in a different engine.
Florida240sx
grimple1 wrote:Probably would've been easier to just swap in a different engine.
Seems that wya.I had no problems with my sohc. Fixing to swap injectors on my dohc....see if I'm lucky again.
