help with tachometer - 240sx ka24de
ric77
Car: 240sx ka24de
Good day, I am writing from Panama
my English is not very good
Buy a 240sx 90 with KA24e and I made him swap a KA24DE, KA24DE was installed with his harness, but the ECU I use is the single cam(ka24e) and tachometer, the tachometer is coming mph digital.
all works fuel, temp, digital km, less rpm (tachometer) does not work
how to fix this the operation of the tachometer?
the ecu problem?
problem by not connecting to the rear plug?
power failure?
what color cable indicates to me the ecu rpm?
thanks
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I don't think you will get tac working without dohc ecu and gauge. If it is a problem with wiring it is the yellow and red stripe wire going from ecu to dash harness. You will have to wire up the plug from the sohc to your dohc harness.
ric77
Car: 240sx ka24de
ric77
Car: 240sx ka24de
help with my problem, i need used tach.
one questions, whats ECU is best, the ka24e or ka24e?, i have both, but my ka24e ecu i have a chip with ebay chip to eliminate the speed limit, the KA24DE has a speed limit?
oh i have the chip with my ka24de also?
I ask this question, because maybe changing the ecu to the tach doch serve me and only I put the chip?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
They use different tachs, you can swap the tach motors.
