Help with suspension question!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
borcan69
Car: 2003 g35 coupe
Hello guys, I recently purchased a set of 19" rims for my G35 and I really need to lower the car now. I put 19x8.5 front, and 19x10 in the back.My question to you guys is: what suspension brand should I get and what the drop should say when I purchase the suspension. I have about 2" gap in the front and 1 1/2 inch back. Please help
Modified by borcan69 at 8:23 AM 1/16/2008
joe603
Car: 2014 Durango R/T
borcan69
Car: 2003 g35 coupe
Will I be needing any rear arm control bars or cambers?!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
TEIN S-Techs from A 350Z
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
you will need new cambers for the rear most likely, unless you wanna run through tires frequently...
1" is about the max you can go with stock cambers, and thats barely within the limit of alignment
borcan69
Car: 2003 g35 coupe
thanks for the help guys!
carmo
Car: 92 Accord, 90 Civic, 89 240sx
If your on the cheap you could always get a custom alignment. Theres a couple of shops in my area that will align a car with wrenches and a torch. But if you wanna go back and do it right you may have to buy OEM parts you otherwise wouldnt have had to buy. just a thought....
CYO44Baseball32
Car: G37S 6MT
Yep but I got G35 s-tech and my car is SLAMMED!! I couldnt even put it on the track for the car wash today lol. Handles like its on rails. I have no probably with tire wear either.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Did you get aftermarket camber adjusters?
CYO44Baseball32
Car: G37S 6MT
No, it doesnt appear to need it either
Sentientbydesign
96 I30 - Sold
I've got stock sport suspension on my coupe and fronts are feathered on the inside. I can't believe that you dropped yours 1-2in and the tires are fine.
Do you have a fairy god mother too? lol
CYO44Baseball32
Car: G37S 6MT
Sentientbydesign wrote:I've got stock sport suspension on my coupe and fronts are feathered on the inside. I can't believe that you dropped yours 1-2in and the tires are fine.
Just a good mechanic
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
