obos »
https://forums.nicoclub.com/obos-u22769.html
Mon Oct 03, 2005 6:06 pm
I have a 95 240sx base model - Auto transmission with 115K. It seems my starter has died on me. Which is kinda strange because I haven't noticed any degredation in starting the car at all. The only thing that was starting to go bad was the engine would sometimes die after it started. But if I gased it a bit right after it started, it was fine. Right before it died, I just drove the car to the store and was returning to get my cell phone from my house. Turned the car off and ran inside the house. Came back out and turned the key and......nothing. Thought my battery was bad or something, but a jump wouldn't do anything. Not even a click. All electronics look OK. All fuses look OK.
Is there test I can do before fussing with it's removal? I read in a thread that I can attach a wire from the Power connector on the starter to the starter soleniod, however I'm not sure where the starter solenoid is. Any clarification would be greatly appreciated.
Also, I read that the removal of the starter on the auto transmission requires droppign the transmission. Is this true.
Unfortunately I still don't have a FSM, so I am still trying to find the upper bolt on the starter. Suggestions, info, anything would be nice. I just need to get my car running so I can go to work.
Thanks in advance
