ADiamond75 »
https://forums.nicoclub.com/adiamond75-u25693.html
Tue Jan 02, 2007 6:15 pm
Got the pinouts from AEM.
Heres what I posted on their site asking for responces
Quote »I am getting ready to purchase an AEM EMS for my 95 240sx. Here's the problem, I have looked at the two diagrams for the 1610 and the 1611 to determine which one will work with my car. It would seem that the car is OD1 because of the pin configuration, however there are some wires that should not be ththeres per the pin out yet are for ODB1, but others that are not there for the ODB2.
For example:Pins 115 not be present in the ODB1 config and should be there for ODB2 - and it is present
Pin 116 should be there on both ODB1 and ODB2 and is not
Pin 117 should not be there for ODB1 and should be there for ODB2 - it is not present
Pins 5 and 6 should not be there for ODB1 and should be there for ODB2 - they are both not there.
Pin 105 should be there for ODB2 and should not be there for ODB1 - it is not present.
So everything is straight except pins 115 an 116. Also, to further compliccomplicate, the car is listed as an ODB2 car on the emmissions under the hood. Please help with this.
Now, onto the other questions. As far as sensors go for the EMS on a 240sx. I will be running between 7-18 psi of boost, which MAP sensor should I use?
I will also be wanting to have a Air/Fuel mixture gauge to monitor the engine, and am planning on getting the wideband sensor regardless, would you recommend the serial gauges or getting the stand alone Wideband?
What is the best way to install the Temp Sensor for the Air?
Also, would I need the Coolent Temp Sensor or Exhaust Backpresure Sensor or Exhaust Gas Sensor? And would they help the performance the car in any way?[/quote]any help would be great!
