AmoebAssassin »
https://forums.nicoclub.com/amoebassassin-u22213.html
Sat Jan 13, 2007 4:51 pm
That's the older taka kit, which has threaded fittings on both sides, rather than the newer taka kit (which you have), that has a banjo on one side, and a threaded fitting on the other side.
So just to reiterate -- use the banjo on the block side, using the stock banjo bolt, and use the threaded 90* fitting side on the turbo.
