Help with sr20's power steering hi pressure line....
deathBooster
Car: 240sx under construction
I HAVE A REdtop SR20 and the metal part of the power steering pump is bent and all the fluid is leaking out.. Is there any place where i can buy the metal piece where the hi pressure rubber line attaches????? do I have to buy the whole line?? cost like $275.. any cheaper choice??
VitaminT
Car: 93 240sx SE
If it is where the rubber touches the line then that won't matter that it is a SR vs. KA. You should be able to get that line for pretty cheap. If you want a OEM Nissan line contact Dan in the advertiser section. I am sure he can get one for you at a good price. I have some business several times with him and he is awsome.
If it is the line that runs from the pump down to the frame rail then that is just a standard 240sx part and you should be able to get it most places.
deathBooster
dude thanks for the reply. The part i need is the metal piece attached to the power steering pump held by 2 bolts.. I still have my ka pump. I will try to put that one on...
