Another area is under the igniter chip (stock mount position), is a valve-like unit. It has about three vacuum line coming out. Don't know where it connects to.
Sorry- Just a newbie learning more about the sr's and doing the swap myself.
MACHSIL80 wrote:I understood about putting the breather on the hardline. It connects to the bottom of the canister. What I meant was what line was connectted to the vacuum ports on top of the canister.
MACHSIL80 wrote:Well, actually they used that canister in Japan because I pulled it out of the front clip that I purchased. I thought it was needed to make the engine work, but after a little reseach and a few calls plus everyones posts, (thanks) that I learned about not needing it. The history of it (from Cartune) is that it was part of the emission control and that it connected to the AIV unit that was removed to make the sr work with the US 240sx's. So thanks everyone.
