duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Sun Jan 13, 2008 9:05 pm
I turned on the car for awhile today after making sure my IC tubes were nice and tight, and also that the vacuum lines were tight. However, it was still the same results. hits 3500RPM at full throttle and wont pass that unless I "pump" the throttle.
When I got back home though, I took out the spark plugs from the cylinders and noticed my number 2 cyclinder was STILL flooded, and seemed a bit worst. I could smell some fuel in the oil, so I'll be changing the oil for that before I drive it again. btw, I allowed tried allowing my cyclinder to evaporate the fuel by pulling out the spark plug for a whole day, doesn't seem to really go away. My other cylinders are dry, its just that number 2.
I'll be making a fuel pressure gauge this week to hook up to the fuel line and see what I'm at.
I also readjusted the TPS to .4V closed. It was at 4.0V at WOT. But that was BEFORE I took it for a drive.
