It is easy to adjust. There is an adjustment screw on the top of the sensor in the cluster. The easy way to do it is to drill a hole through the cluster so you can put a screwdriver in there without taking it out each time. Turn it, follow someone, stop adjust, follow, stop adjust follow. Takes a while but should do the the trick.FAST-DATSUN wrote:you tire size could be the problem if the smaller or larger than stock...
