Help with speedo- which wires/plus?
cadet
Car: 89 s13 coupe
I know I've asked this a few times, but does anyone know what wire the speedo should be on the dash plug, and what plugs it uses on the main harness? I swapped in my usdm speed sensor and plugged it in but I'm still getting 0 mph on my speedo, so I think there is a problem with the wiring somewhere.I really need help with this... thanks.
RMiller
Car: BBQing
It only plugs in one way. Speed sensor plugs into the lower harness, and that untimately plumbs into the dash where you just plug in the cluster.
float_6969
Lots of help you are Ryan.....Hehehehe
IIRC it's yellow with a green stripe...
cadet
Car: 89 s13 coupe
thats what I thought (about it plugging into the subharness and going from there to the dash harness). I'll check the yellow w/green when I get home and see what its plugged into....
