Help with some final odds and ends
002-M-P
Car: Z33-RB26 IP
I'm trying to finalize any odds and ends parts that I need to complete my RB26 swap (all i'm waiting on is the damn machine shop...i was told 6 weeks to do the work, it has now been 10 weeks and all they have done is bored and honed the block...still have head work, balancing, reconditioning rods, and so on)....Anyways....
I am ordering my oem thermostat (P/N: 21200-42L06) today and figured I would get anything else that I might need. First thing that came to mind was clutch throwout bearing and pilot bushing. I have found P/N: 30502-45P00 on the skyline forum at fresh alloy for the throwout bearing. I also have P/N: 32202-B9500 for the pilot bushing, which seems to correspond with alot of Nissan cars over the past 15 years (240sx, 300zx, 350z, frontier, pathfinder, etc). The last part number for the clutch assembly that I have is for the "Bearing sleeve" (P/N: 30501-S0284) but I am unsure of exactly what this is.
If anyone can confirm these before I order that would be good and any other ideas of what I should order. Thanks.
PS...I already have the timing idler and tensioner pullies and full gasket set.
gawdzilla
Car: none
i think the bearing sleeve is the part that the clutch fork actually moves. the TO bearing is attached to it and you press it onto the bearing sleeve. cant imagine what else it would be..
002-M-P
Car: Z33-RB26 IP
alright well i don't know if I should even bother ordering that then
gawdzilla
Car: none
you might as well... it can be a pain getting the old TOB pressed off if you don't have a press, plus its like a $20 part? i think all of the clutch actuating parts including the fork and TOB retaining clip are all usdm anyway...
