Help with setting up timing on my G35
PDog
Car: 2003 Infiniti G35 Coupe 3.5
I'm a newbie so be gentle. My first post. Here it goes and I'm sure you have seen this a dozen times. Lets say here the timing on my 2003 g35 coupe 3.5 is just screwed up. Only thing is the short timing chains on bank one and 2 have not been removed at all so they should be good to just time. I did have to turn both banks to get them set where they are at. Looking at the photos is the timing set correctly? BTW this happened when replacing the water pump which end the end didn't need to be changed but that's another story.
PDog
I guess this is tougher then I thought sense I'm getting no reply's. I posted this in another forum and only got crickets there also. Thanks for viewing my post though.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's not enough res in those pics to see where all the mating marks are, but you can find all the lineup info on EM-84 here:
https://www.nicoclub.com/service-manual ... 5%2Fem.pdf
